10 years agoModelSim Altera Starter Edition 10.4d And Quartus Prime Lite 16.0 Compiler Issue
My ModelSim Altera Starter Edition 10.4d comes with IEEE.float_pkg.
It can also compile float_pkg_vhdl2008.vhd into WORK library. Simulation works fine for WORK.float_pkg and IEEE.float_pkg. However, my Quartus Prime Lite Edition 16.0 cannot compile float_pkg_vhdl2008.vhd. It shows Error (10500): VHDL syntax error at float_pkg_vhdl2008.vhd(48) near text "new"; expecting "end", or a declaration statement. It cannot detect both the WORK.float_pkg (compiled by ModelSim) and IEEE.float_pkg. Error (10481): VHDL Use Clause error at Transport_Layer.vhd(7): design library "work" does not contain primary unit "float_pkg". Verify that the primary unit exists in the library and has been successfully compiled. Error (10481): VHDL Use Clause error at Transport_Layer.vhd(7): design library "IEEE" does not contain primary unit "float_pkg". Verify that the primary unit exists in the library and has been successfully compiled. How to fix this issue? Thank you.No RepliesBe the first to reply
