12 years agosorry I don't understand. by sims I am referring to rtl simulations
if it works in rtl simulations, and you are confident in your timing constraints (and is timing is closed), it should work in actual hardware honestly timing analysis is key because that will expose stuff like cross-clock transfers and long combinatorial chains
