12 years ago --- Quote Start --- I'd suggest sticking with RTL simulation and use timing tools to achieve multi-corner closure. if it works in sims and you're confident in your constraints, it should work in synth --- Quote End --- Hello jderrick. Is sims separated from quartus/modelsim? I have only used it for transistor level simulation and have no idea how it works for FPGA simulation...Will it simulate the code on transistor level by default if I simply run it? Thanks!
