12 years ago --- Quote Start --- I have no idea why it would crash. However, faced with the same issue, I would try another version of Modelsim-ASE, and also the full version of Modelsim-SE. You could probably download the matching version of Modelsim-SE for evaluation from the Mentor site. Do not start with the "latest" version of Modelsim-SE, always use the same version that Altera provides as Modelsim-ASE. I have had experiences where the different versions are not compatible, eg., dual-ported RAM did not work correctly. --- Quote End --- I see. I will try what you recommended. Thanks a lot for your help! David
