12 years ago --- Quote Start --- I can't get a board in short time and I do need to get my design verified for post synthesis. Would you please list some potential/common reasons for my problem, so that I can take a look at that and maybe get the problem solved if I am lucky enough :) --- Quote End --- I have no idea why it would crash. However, faced with the same issue, I would try another version of Modelsim-ASE, and also the full version of Modelsim-SE. You could probably download the matching version of Modelsim-SE for evaluation from the Mentor site. Do not start with the "latest" version of Modelsim-SE, always use the same version that Altera provides as Modelsim-ASE. I have had experiences where the different versions are not compatible, eg., dual-ported RAM did not work correctly. Cheers, Dave
