12 years ago --- Quote Start --- Could someone please give me some help? Any idea is appreciated! --- Quote End --- Don't do it. (You did say "any idea") Seriously though, if your RTL simulation works fine, and your design passes timing, then test it in hardware. If it does not work in hardware, then sure, go back and see if the gate-level also fails, however, even that is no guarantee. Ultimately you need to run the design in hardware. Cheers, Dave
