11 years ago
ModelSim-Altera Problem with PLL IP Core
I have some simple VHDL code. One file has an UNSIGNED counter: signal count : unsigned(3 downto 0);
The TOP level entity has the clock as input. If I use this clock for the counter which is an instantiated
entity the counter works.
If a use a clock output from a PLL the counter does not work. Not only that, but the counter is not reset to 0
when the reset pulse occurs.
The PLL clock is causing some simulation problems.
Any idea?
1 Reply
    Found the problem.
    My code uses a "synchronous" reset. If one uses a reset on the PLL then all clocks are stopped during the reset.
    Thus, no reset code will be executed.!
    Solution: Permanently tie PLL reset to GND.
