14 years ago
ModelSim AE vs SE and "transcript file xxx"
I have some difficulties with ModelSim AE. My goal is to open a read/write channel between ModelSim and an external program. This works fine with ModelSim SE and it's done as follow:
in "my_macro.do" :
fconfigure $MyChannel -blocking 0 -buffering line
fileevent $MyChannel readable "readMe $MyChannel"
transcript file $MyChannel
OK. From this point,
  • With both ModelSim, if I type "puts $MyChannel string", the string is correctly sent to $MyChannel.
BUT, the transcript text there is a problem :
  • with ModelSim SE : the transcript is correctly redirected to $MyChannel.
  • with ModelSim AE, a file called $MyChannel is created. The value of this variable is always filexxxxxxx (file with 7 hexadecimal digit).
My external program needs to receive the transcript to correctly functionnate. The PDF Reference Manual for "transcript file" for both ModelSim AE/SE is exactly the same.
Does someone know how to output the transcript file to a channel under ModelSim AE ?
Thanks in advance.
Regards.
