--- Quote Start ---
This is a tool issue. I assume the shift occurs after result of addition is put into basket rather than add shift then insert. I am just explaining my assumption about your observation.
Or put this way: modelsim does not do any bit extension and just uses your register sizes. .
--- Quote End ---
Modelsim does what IEEE 1364 requires. Before blaming the tool, take a look at the Verilog specification which discusses an example similar to the present one.
--- Quote Start ---
5.4.2 Example of expression bit-length problem
During the evaluation of an expression, interim results shall take the size of the largest operand (in case of an assignment, this also includes the left-hand side). Care has to be taken to prevent loss of a significant bit during expression evaluation. The example below describes how the bit lengths of the operands could result in the loss of a significant bit.
Given the following declarations:
reg [15:0] a, b, answer; // 16-bit regs
the intent is to evaluate the expression
answer = (a + b) >> 1; //will not work properly
where a and b are to be added, which can result in an overflow, and then shifted right by 1 bit to preserve the carry bit in the 16-bit answer.
A problem arises, however, because all operands in the expression are of a 16-bit width. Therefore, the expression (a + b) produces an interim result that is only 16 bits wide, thus losing the carry bit before the evaluation performs the 1-bit right shift operation.
--- Quote End ---
