GLous1
7 years agoModelsim 10.5b Intel FPGA licenses error,
Hi all, I'm getting a license error that I never had before on the same project, the licensces showed are working, I can see them with lmtools and quartus. when I run # vsim -novopt -t ps -L work ...
Abe
7 years agoIn this case, check the license environment variables in your system, also check if you any firewall has been enabled recently and if necessary add exceptions for these ports in the firewall or disable the firewall and try if you can get the license to work
