15 years ago --- Quote Start --- changed "signed" to "SIGNED" --- Quote End --- Thank Tricky. I done it. The result is ok, But it still has a little error at the biginning, when time is 0 ns. Could you check it for me. thanks This is error --- Quote Start --- # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/adder1/l2/v# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/adder1/l2/v# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/adder1/l2/v# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/mull# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/mull# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 0 ns Iteration: 0 Instance: /testbench_step/u/mull --- Quote End ---
