15 years agoDear Kaz
Why I can not use port map inside of If command? Could you check this code for me? In this code, I use a component multvhdl to multiply A0 and X0. When I push the port map, Quartus alway say the error at port map. Thanks Kaz very much.LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_arith.all;
USE IEEE.std_logic_signed.all;
USE IEEE.numeric_std.all;
ENTITY STEP IS
port(CLK, CLK_40n :IN STD_LOGIC;
X0 :IN STD_LOGIC_VECTOR(15 downto 0);
Yn :BUFFER STD_LOGIC_VECTOR(15 downto 0));
END STEP;
ARCHITECTURE STEP_arch OF STEP IS
Component Multvhdl
Port (
A,B : In Signed(15 downto 0); --A*B
Result_out : Out Signed(31 downto 0);
CLK : In std_logic);
end component;
SIGNAL A0,A1,A2,A3,A4 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL B1,B2,B3,B4 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL Y4,Y3,Y2,Y1 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL X1,X2,X3,X4 :STD_LOGIC_VECTOR(15 downto 0);
--SIGNAL mula,mulb :STD_LOGIC_VECTOR(15 downto 0);
--SIGNAL mulr :STD_LOGIC_VECTOR(31 downto 0);
SIGNAL adda,addb,addr :STD_LOGIC_VECTOR(31 downto 0);
SIGNAL CNT :STD_LOGIC_VECTOR(4 downto 0);
BEGIN
A0 <= "0000000000000011";--3
A1 <= std_logic_vector(to_signed(16#000B#,16));--11
A2 <= std_logic_vector(to_signed(16#0011#,16));--17
A3 <= std_logic_vector(to_signed(16#000B#,16));--11
A4 <= std_logic_vector(to_signed(16#0003#,16));--3
B1 <= std_logic_vector(to_signed(16#5D3F#,16));--23871
B2 <= std_logic_vector(to_signed(16#9A14#,16));-- -26092
B3 <= std_logic_vector(to_signed(16#3181#,16));--12637
B4 <= std_logic_vector(to_signed(16#F6FF#,16));-- -2305
GEN:block
BEGIN
PROCESS(CLK_40n,CLK)
BEGIN
IF CLK_40n'EVENT and CLK_40n='1' THEN
CNT <=CNT+1;
IF CNT="00000" THEN
M0: Multvhdl port map (A0,X0,adda,CLK);
ELSIF CNT="00001" THEN
addb <= A1*X1;
ELSIF CNT="00010" THEN
adda <= adda+addb;
addb <= A2*X2;
ELSIF CNT="00011" THEN
adda <= adda+addb;
addb <= a3*x3;
ELSIF CNT="00100" THEN
adda <= adda+addb;
addb <= a4*x4;
ELSIF CNT="00101" THEN
adda <= adda+addb;
addb <= B1*Y1;
ELSIF CNT="00110" THEN
adda <= adda+addb;
addb <= B2*Y2;
ELSIF CNT="00111" THEN
adda <= adda+addb;
addb <= B3*Y3;
ELSIF CNT="01000" THEN
adda <= adda+addb;
addb <= B4*Y4;
ELSIF CNT="01001" THEN
Yn <= adda(15 downto 0)+addb(15 downto 0);
ELSIF CNT="01010" THEN
Y1 <= Yn;
Y2 <= Y1;
Y3 <= Y2;
Y4 <= Y3;
X4 <= X3;
X3 <= X2;
X2 <= X1;
X1 <= X0;
CNT <= "00000";
END IF;
END IF;
END PROCESS;
END BLOCK GEN;
END STEP_arch; When I push port map outside IF command, it's ok. But I can not do that for this code.
