15 years agoI'm sorry.
I had checked it carefully. This is error:
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(21): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(22): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(23): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(24): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(25): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(26): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(27): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(28): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(29): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(37): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(37): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(41): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(41): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(45): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(45): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(49): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(49): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(54): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(54): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(59): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(59): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(65): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(65): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(70): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(70): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(75): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(75): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(81): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(81): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(85): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(85): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(87): No feasible entries for infix op: "="
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(87): Type error resolving infix expression.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(96): Type error in bit string literal. Type std_logic_vector is not an array of bit.
** Error: D:/Quartus_code/ExModelSim/HW2/step.vhd(101): VHDL Compiler exiting
This is my code:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_arith.all;
USE IEEE.std_logic_signed.all;
USE IEEE.numeric_std.all;
ENTITY STEP IS
port(CLK, CLK_40n :IN STD_LOGIC;
X0 :IN STD_LOGIC_VECTOR(15 downto 0);
Yn :BUFFER STD_LOGIC_VECTOR(15 downto 0));
END STEP;
ARCHITECTURE STEP_arch OF STEP IS
SIGNAL A0,A1,A2,A3,A4 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL B1,B2,B3,B4 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL Y4,Y3,Y2,Y1 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL X1,X2,X3,X4 :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL mula,mulb :STD_LOGIC_VECTOR(15 downto 0);
SIGNAL mulr :STD_LOGIC_VECTOR(31 downto 0);
SIGNAL adda,addb,addr :STD_LOGIC_VECTOR(31 downto 0);
SIGNAL CNT :STD_LOGIC_VECTOR(7 downto 0);
BEGIN
A0 <= x"0003";--3
A1 <= x"000B";--11
A2 <= x"0011";--17
A3 <= x"000B";--11
A4 <= x"0003";--3
B1 <= x"5D3F";--23871
B2 <= x"9A14";--- -26092
B3 <= x"3181";---12637
B4 <= x"F6FF";--- -2305
GEN:block
BEGIN
PROCESS(CLK_40n)
BEGIN
IF CLK_40n'EVENT and CLK_40n='1' THEN
CNT <=CNT+1;
IF CNT=x"00" THEN
mula <= A0;
mulb <= X0;
ELSIF CNT=x"01" THEN
adda <= mula*mulb;
mula <= A1;
mulb <= X1;
ELSIF CNT=x"02" THEN
addb <= mula*mulb;
mula <= A2;
mulb <= X2;
ELSIF CNT=x"03" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= A3;
mulb <= X3;
ELSIF CNT=x"04" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= A4;
mulb <= X4;
ELSIF CNT=x"05" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= B1;
mulb <= Y1;
ELSIF CNT=x"06" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= B2;
mulb <= Y2;
ELSIF CNT=x"07" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= B3;
mulb <= Y3;
ELSIF CNT=x"08" THEN
adda <= adda+addb;
addb <= mula*mulb;
mula <= B4;
mulb <= Y4;
ELSIF CNT=x"09" THEN
adda <= adda+addb;
addb <= mula*mulb;
ELSIF CNT=x"0A" THEN
Yn <= adda(15 downto 0)+addb(15 downto 0);
ELSIF CNT=x"0B" THEN
Y1 <= Yn;
Y2 <= Y1;
Y3 <= Y2;
Y4 <= Y3;
X4 <= X3;
X3 <= X2;
X2 <= X1;
X1 <= X0;
CNT <= x"00";
END IF;
END IF;
END PROCESS;
END BLOCK GEN;
END STEP_arch;
