14 years ago
Modelsim - trouble passing $ parameter from vsim to vlog
Hello all, I'm stumped on how to do something in modelsim. I was hoping maybe someone here has maybe done this before and can point me in the right direction. I think this must be a very common thing to do...
What I'm trying to do:
I am trying to pass in the name of a test file at the modelsim vsim command line. The whole idea is that everything in the sim environment stays the same and I have a number of these test files I feed into the simulation.
so my command would look something like this:
do run.do m3m_test_case
I am trying to pass in a $ parameter (m3m_test_case) from the modelsim vsim command line and use it in a vlog I'm able to pass in the $ parameter and use it for various other things, but when I try to use it in a vlog command, the vlog interprets it literally instead of converting it to the string I want.
This is my code in the do script
set m3m_test_case m3m_test_$1.v
vlog -vlog01compat -work work +incdir+../tests {../tests/"$m3m_test_case"}
This is the error message I get # Model Technology ModelSim ALTERA vlog 6.6d Compiler 2010.11 Nov 2 2010 # ** Error: (vlog-7) Failed to open design unit file "../tests/"$m3m_test_case"" in read mode. # Invalid argument. (errno = EINVAL)# ** Error: C:/altera/11.0/modelsim_ae/win32aloem/vlog failed. # Error in macro ./run_mpts_default.do line 141 # C:/altera/11.0/modelsim_ae/win32aloem/vlog failed. # while executing# "vlog -vlog01compat -work work +incdir+../tests {../tests/"$m3m_test_case"}"
Instead of evaluating the $m3m_test_case it treats it literally. It's almost like I need to escape it somehow or something. But I'm not sure how.
The following command works just fine so i know it's passing in the right stuff
code:
echo "this is the argument passed in: $m3m_test_case"
vsim command line: # this is the argument passed in: m3m_test_mpts_default_110709.v
Any help on this would be greatly appreciated.
    {} stops Tcl from expanding the variable.
    Use " " in place of {}
    vlog -vlog01compat -work work +incdir+../tests "../tests/$m3m_test_case"
    or just leave them out
    vlog -vlog01compat -work work +incdir+../tests ../tests/$m3m_test_case
    You can also use environment variables
    vlog -vlog01compat -work work +incdir+$env(TESTS) $env(TESTS)/m3m_test_case
    where TESTS is an environment variable pointing to your tests folder.
    Cheers,
    Dave
    Thanks Dave!
    I tried the quotes just as you said and it worked perfectly!
    Best Regards
