10 years agomod operation synthesis (Avalon-MM master writing to DRAM problem)
Hi. I'm trying to write a simple Avalon-MM master component which writes an image to the DRAM memory. I use this component in a Qsys system with Nios II/e processor, SDRAM controller and University P...
10 years agoYou asked for 20 ns clock period, but with a worst case slack of -24.5ns it means the data can arrive 24ns late (ie over an entire clock period). This analysis is the worst case (the design will be affected by temperature) but basically, its very bad. It means that the FMax you can use to guarantee data arrival before the clock is 20+24.5 ns = 44.5ns (about 22 MHz).
Dont use a mod operation for non 2**N values.
