10 years agomod operation synthesis (Avalon-MM master writing to DRAM problem)
Hi. I'm trying to write a simple Avalon-MM master component which writes an image to the DRAM memory. I use this component in a Qsys system with Nios II/e processor, SDRAM controller and University P...
10 years ago --- Quote Start --- The problem with the mod or rem operators when they are not 2**N, is that it implements a divider. These have terrible timing performance in a single clock cycle (about 20MHz if you're lucky). So the fact that you're using a 167MHz clock probably meant it was basically producing random values. Do you have timing constraints for the design? did you look at them and see the failures? --- Quote End --- Tricky, thank you. I guess you're right. I haven't learned the timing analysis part of the design yet. I added the following *.sdc file to my project:
create_clock -name clock_50 -period 20
derive_pll_clocks
derive_clock_uncertainty
And here's the "red" TimeQuest report I get with the mod operation: https://docs.google.com/spreadsheets/d/1pumvhheg8nyqjznpagodadgxgcndvcolb7laxp3bmym/pubhtml I don't know how to interpret this yet but I guess that's you're talking about. Would you please briefly explain what this report say?
