10 years agoMMD ERROR while connecting to board
Hi ive got some troubles setting up an initial Hello World (for opencl) . (windows7, 64) the current error I get is " MMD ERROR: failed to scan for the PCI device." this error is app...
10 years ago --- Quote Start --- Check Device Manager, you should see Jungo installed, but you should also see the A10 Reference board under the "Accelerators" group. You should also run "aocl diagnose" and see if that passes. --- Quote End --- hi,pnac i have install the driver successful, and i also can see Jungo intalled and the a10_ref board under "Accelerators" group. but when i invoke "aocl diagnose " ,the error message is printing “MMD INFO : [acla10_ref0] PCIe-to-fabric read test failed, read 0xffffffff after 1 attempts Phys Dev Name Status Information acla10_ref0 Failed Board name not available. Failed initial tests, so not working as expected. Please try again after reprogramming the device.” could you give me some suggestion? thanks for any help
