mm_interconnect generation for system with PCIe EP, HBM2 Controllers and AXI interface IPs
Hi ,
I am trying to build a system with PCIe EP, HBM2 Controllers and AXI interface IPs.
But facing issues with Address Mapping for slaves.
HBM Address Range : 0x0_0000_0000 to 0x1_FFFF_FFFF (32 instances of 256MB HBM slices)
DUT Address Range : 0x2_0000_0000 to 0x2_00FF_FFFF
HOST System Memory Address Range : 0x4_0000_0000 to 0x5_FFFF_FFFF
Q) I have set the Slave port Address widths at 38 bits for all the slaves. Is this a correct method, Or do I need to set the address port width as the slave Address range(e.g, 24 bits for my DUT)?
I am using one AXI Master BFM and one AXI Slave BFM to build mm_interconnect.
Is there a way to use Blackbox components to build mm_interconnect in Quartus Platform Designer? If yes , Please share the procedure.
Quartus Version: quartus_prime_pro/21.2.0.72
Siva Kona
I could resolve this issue after few experiments.
Siva Kona
1 Reply
- SivaKona
Siva Kona
