17 years agoMismatched Nodes
I am designing a 4 bit ripple adder using input and output buses. They are named A[3..0],B[3..0] and Sum[3..0]. When I try to simulate the circuit though I get these errors: Warning: Wrong node ty...
17 years ago --- Quote Start --- I am designing a 4 bit ripple adder using input and output buses. They are named A[3..0],B[3..0] and Sum[3..0]. When I try to simulate the circuit though I get these errors: Warning: Wrong node type and/or width for node "|AdderRipple|A" in vector source file. Node in design is of type Bus and of width 4, but node in vector source file is of type 9-Level and of width 1. Error: Can't simulate mismatched node types Warning: Wrong node type and/or width for node "|AdderRipple|B" in vector source file. Node in design is of type Bus and of width 4, but node in vector source file is of type 9-Level and of width 1. Error: Can't simulate mismatched node types Warning: Wrong node type and/or width for node "|AdderRipple|Sum" in vector source file. Node in design is of type Bus and of width 4, but node in vector source file is of type 9-Level and of width 1. Error: Can't simulate mismatched node types Error: Quartus II Simulator was unsuccessful. 3 errors, 3 warnings What am I doing wrong here? --- Quote End --- Hi, how did you define your inputs in the vector file ? I assume you have a small test project. Can you post it in the forum ? Kind regards GPK
