15 years agoI think you can't avoid this. If I understand correctly, you want to change the delay "on the field" in order to adjust the timing "artificially". So TQ analysis makes no sense in this case.
If the input and output clocks of the delay line are related to different clock domains, you can simply set a false path between them to avoid the violation warning.
