10 years agoMigration from megawizard to qsys ip
Hello, I have to convert an older cycloneIII design to a new cycloneV SOC design. The original design was created using Quartus12.1 and contains a lot of megawizard generated ip cores. The new ...
10 years agoQuartus 15.1 should compile your old design just fine. What cores are you worried about?
Many cores can be migrated inside quartus using auto-update. Annoyingly though, some cores have to be manually migrated, and this will require re-generating the cores (like PCIE). Even more annoyingly, I have found transceiver settings are not modifyable via the QSYS interface - you have to tweak the generated code BY HAND!! Its a bit of a shambles - some of the IP catalogue is just a front to load the megawizard.
