Harry123
1 year agoMigration from 10M08DCU324 to 10M16DCU324
I have project which is build on 10M08DCU324 and same i am traying to migrate it to 10M16DCU324. After migration PLL block in my project is not working, just to check whether PLL is working or not i ...
Farabi_Altera
1 year agoHello,
PLL design should be straight forward. Please make sure you recompile the design after you change devices and make sure the pin assignments are connect following the physical pin connection on your board.
Please make sure your clock oscillator is driving the correct IO standard signal into FPGA(please make sure the same IO standard is defined in IO pin planner as well).
regards,
Farabi
