9 years agoMigrating from Quartus 15 to 16, design no longer fits on device
Good day I have attempted to migrate a design from Quartus v15.0 to Quartus v16.1.2. I updated all IP components used and worked through the port_diff_report, no major changes. When c...
9 years agoIn the fitter report you'll find an entry called "Resource Utilization by Entity". It will give you resource usage for each entity. You can compare the reports for both versions to check which entity uses now more resources. Then look for that entity name in the compiler warnings and see if you can find any message explaining why it is using more resources.
