Microsoft visual studio 2017 professional with HLS
Hi!
I see that the HLS compiler (Quartus Prime Pro 18.1) works with Microsoft Visual Studio IDE 2015 Professional. I would like to know if it works with Visual Studio 2017 Professional?
Kindly confirm.
Nivetha
- AnandRaj_S_Intel
Hi Nivetha,
Few quarters ago i was trying to use Quartus 17 std with Visual Studio 2017 but i was facing lot of issue so i used Visual Studio 2010 as per documents.
Presently i am using Quartus 17, 18 both std & pro edition with Visual Studio 2010 for simple design, so far i have not faced any issue.
However the Intel HLS Compiler software does not support versions of Microsoft Visual Studio other than those specified for the edition of the software.
Anand Raj Shankar
- MuhammadAr_U_Intel
Contributor
Hi Nivetha,
As pointed out by @Anand
Please refer to Intel HLS Getting Starter guide to see the version of Visual Studio/ GCC supported .
Un-fortunately Intel HLS Compiler software does not support versions of Microsoft Visual Studio other than those specified for the edition of the software.
Arslan
- NSuku1
Okay. Thanks for the clarification.
Nivetha
- NSuku1
Hi all!
Can I use some other IDE other than Microsoft visual studio 2010 ?
Please let me know!
Nivetha
Contributor
You can try using Eclipse following the guide.
https://www.intel.com/content/altera-www/global/en_us/index/documentation/xfy1510159781700.html
Arslan
- NSuku1
Okay. Thank you.
Best,
Nivetha
- NSuku1
Hi all!
I'm using Intel Quartus Prime software standard version. As per the specification given by Intel, I can use Microsoft Visual Studio 2010 Professional for HLS development. However, I could not download this older version of Microsoft Visual Studio as it is not available in the original website.
I hope there should be some alternative to this issue.
Nivetha
Contributor
Did you tried the Eclipse ?
You can download Microsoft Visual Studio 2010 from link below.
https://visualstudio.microsoft.com/vs/older-downloads/
Arslan
