14 years agomgcld exited with status 27
Hi
We've just bought Quartus II software with Modelsim-Altera We received the License activation code and login to the Altera website to obtain the licence .dat file. We modified the license file to adapt the Server with our configuration SERVER my_server 00B0D0ABCCBA 1800 VENDOR alterad D:\quartus\bin\alterad.exe VENDOR mgcld D:\exemplar\leospec\license\win32\mgcld.exe USE_SERVER When we try to run the server diamond, we have the following error : :57:52 (lmgrd) US Patents 5,390,297 and 5,671,412. 15:57:52 (lmgrd) License file(s): 1-7N1W49_License.dat 15:57:52 (lmgrd) lmgrd tcp-port 1900 15:57:52 (lmgrd) Starting vendor daemons ... 15:57:52 (lmgrd) Started alterad (pid 3028) 15:57:52 (lmgrd) Started mgcld (pid 2708) 15:57:57 (lmgrd) alterad exited with status 27 (No features to serve) 15:57:57 (lmgrd) alterad daemon found no features. Please correct 15:57:57 (lmgrd) license file and re-start daemons. 15:57:57 (lmgrd) 15:57:57 (lmgrd) This may be due to the fact that you are using 15:57:57 (lmgrd) a different license file from the one you expect. 15:57:57 (lmgrd) Check to make sure that: 15:57:57 (lmgrd) 1-7N1W49_License.dat 15:57:57 (lmgrd) is the license file you want to use. 15:57:57 (lmgrd) 15:57:57 (lmgrd) mgcld exited with status 27 (No features to serve) 15:57:57 (lmgrd) mgcld daemon found no features. Please correct 15:57:57 (lmgrd) license file and re-start daemons. 15:57:57 (lmgrd) 15:57:57 (lmgrd) This may be due to the fact that you are using 15:57:57 (lmgrd) a different license file from the one you expect. 15:57:57 (lmgrd) Check to make sure that: 15:57:57 (lmgrd) 1-7N1W49_License.dat 15:57:57 (lmgrd) is the license file you want to use. 15:57:57 (lmgrd) Can someone help us on this issue? Thank in advance Marco
