BigHandsomeBee
4 years agoMentor Verification AXI IP Simulation Error with ModelSim-AE
I'm using Quartus Prime Pro 21.2, and I'm running the example following the document provided by Intel.
Chapter 12
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/men...
sstrell
4 years agoI'm not sure what the -c switch does in your command line. You have to make sure to change the directory in ModelSim to point to the location of the simulation files. The guide has you do this in the GUI (page 681). Probably not the issue.
What does the code in the generated top.sv file say at those lines?
