9 years agoMemory overflow in emulation
Hello, I am trying to debug an opencl program with 3 kernels cascade which read global memory at the beginning, communicate thru channels and write the global memory at end. The first kernel has...
9 years agoI personally avoid using channels as much as possible and perform all of my debugging on a standard CPU (unless I have to use channels), so I have never encountered this. Have you tried reducing your input size (rather than dimension size)? If all else fails, you can always open a support ticket directly with Altera.
