13 years agoMemory mapped IO query
I have regular ROM & RAM working via altsyncram and now I'm trying to build some memory-mapped IO for my hobby CPU/SoC. The MMIO code is pretty simple:library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library work;
use work.CPU_Definitions.all;
-- SUBTYPE OpData_Type is natural range 0 to 2**RAM_WIDTH-1; -- actually defined in my definitions package
entity MMIO is
PORT (
signal clock : IN std_logic;
signal MMIO_address : IN natural;
signal MMIO_data_in : IN OPDATA_TYPE;
signal MMIO_data_out : OUT OPDATA_TYPE;
signal MMIO_wren : IN std_logic
end entity MMIO;
architecture behaviour of MMIO is
CONSTANT num_MMIO_BYTES : natural := 2;
TYPE MMIO_Type is array (0 to num_MMIO_BYTES-1) of std_logic_vector(7 downto 0);
signal MMIO_array : MMIO_Type; -- this is mapped to physical pins in my top entity.
begin
MMIO_process: process(clock)
begin
if rising_edge(clock) then
if MMIO_wren = '1' then
assert false report "writing "&integer'IMAGE(MMIO_data_in)&" to MMIO_address "&integer'IMAGE(MMIO_address) severity WARNING;
MMIO_array(MMIO_address) <= std_LOGIC_VECTOR(to_unsigned(MMIO_data_in, MMIO_array(MMIO_address)'length));
else
MMIO_data_out <= to_integer(unsigned (MMIO_array(MMIO_address)));
end if;
end if;
end process MMIO_process;
end architecture behaviour;
When I simulate this, I see the correct data and address being passed into this process, and MMIO_wren is high. I've confirmed this with an assert statement. All values are within allowed parameters (address=1, data=0x55). However, the value is never stored in the actual array element and I can't see why. Furthermore, at the top level, I get warnings that the pins are forced to ground. Any advice would be appreciated. Thanks, Mark
