Morten2000
3 years agoMemory map problems
Hi
I am using Quartus 18.1 with a NIOS processor and uses Eclipse Mars 2.
I have a working system where I have an onchip_mem and an onchip_flash. I can then have some registers in the mem saved t...
- 3 years ago
Found the mistake.
The memory initialization file was pointing to a wrong file.
EBERLAZARE_I_Intel
3 years agoHi,
Your image seems too small, can you share your .qsys file? I can take a look.
May I know what is your intent for your design? Do you just want to access these registers on the OCRAM? And do some read and write?
- Morten20003 years ago
Found the mistake.
