Memory map problems
- 3 years ago
Found the mistake.
The memory initialization file was pointing to a wrong file.
Which settings for the "I am trying to increase the number of registers from 42 to 70." in the Platform Designer did you change?
Can you take a screenshot of that?
Also, if you remain to the original the number of registers of 42 does it work as exepected?
- Morten20003 years ago
Thank you for your reply.
If I just keep the code as it is and keeps the registers at 42 it doesn't work if I use the "Assign Base Addresses".
The code still works, but it doesn't have access to the Flash memory.
I guess it is because onchip_flash.csr changes from 0x00109340 to 0x00109338. I would think that a compile would be enough to make the change and everything work. But that is not the case.
Is there something I am missing?
