12 years agoHI,
Thank you very much for help , basically i am beginner so it is quite confusing for me, i am pasting the Error again following in order to seek help Info: Found 2 design units, including 1 entities, in source file latchSR.vhd Info: Found design unit 1: latchSR-rtl Info: Found entity 1: latchSR Error (10430): VHDL Primary Unit Declaration error at modulatore30aprile.vhd(devil): primary unit "modulatore30aprile" already exists in library "work" Info (10499): VHDL information at azhar.vhd(devil): object "modulatore30aprile" is declared here Info: Found 0 design units, including 0 entities, in source file modulatore30aprile.vhd Info: Found 2 design units, including 1 entities, in source file modulatore30apriletest.vhd Info: Found design unit 1: modulatore30apriletest-architettura1 Info: Found entity 1: modulatore30apriletest Error (10430): VHDL Primary Unit Declaration error at modulatore_finale.vhd(devil): primary unit "modulatore_finale" already exists in library "work"Info: Found 2 design units, including 1 entities, in source file sel_shift.vhd Info: Found design unit 1: sel_shift-scalamento Info: Found entity 1: sel_shift Info: Found 2 design units, including 0 entities, in source file sine_package.vhd Info: Found design unit 1: sine_package Info: Found design unit 2: sine_package-body Info: Found 2 design units, including 1 entities, in source file sine_wave.vhd Info: Found design unit 1: sine_wave-arch1 Info: Found entity 1: sine_wave Info: Found 2 design units, including 1 entities, in source file sinewavecomplex.vhd Info: Found design unit 1: sinewavecomplex-arch11 Info: Found entity 1: sinewavecomplex Info: Found 2 design units, including 1 entities, in source file Vhdl2.vhd Info: Found design unit 1: vhdl2-rtl Info: Found entity 1: vhdl2 Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Info: Allocated 151 megabytes of memory during processing Error: Processing ended: Mon Jul 08 15:31:40 2013 Error: Elapsed time: 00:00:02 Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings could you please help?
