spapp2
7 years agomegawizard plugin does not launch
Hello, i have quartus 16.1. i have a pll that is instantiated and the outputs are set in the project that was given to me. I am trying to open the pll setting to add another output, but cannot get me...
Vicky1
7 years agoHi,
This may be a bug caused by re-branding of Intel IP.
Until this is fixed, you can fix this like below,
> locate the .lst file of the missing IP in your IntelFGPA program directory(C:\intelFPGA_lite\18.1\ip\altera\altera_iopll), for example for the missing PLL, locate: "altera_iopll_wizard.lst"
> Change the text:
"<ALIAS>Altera PLL v16.1</ALIAS> "
(and higher version numbers) to:
"<ALIAS>PLL Intel FPGA IP v16.1</ALIAS>"
make a entry until "<ALIAS>PLL Intel FPGA IP v18.1</ALIAS>" in .lst file & save & then try to open parameter editor.
please let me know , how it works to you.
Vicky
