16 years agoIf you set the max block depth 512 then the megawizard will report resource usage of 25 lut + 4 M4K + 2 reg.
I've no idea why this wouldn't be true in the fitter results however.If you set the max block depth 512 then the megawizard will report resource usage of 25 lut + 4 M4K + 2 reg.
