Max+Plus II License request is no reply again.
5 months ago, I didn't get the reply email for the MAX + plus II license request, and I was able to get it by having the Licensing Request portal recovered(?).
But now, when I request a license for a new machine, I'm not getting mail again.
(Even if you wait more than 24 hours)
I saw some similar recent questions in this forum, but have anyone got it?
If so, how did you get it?
- AR_A_Intel
Hi Sir
Apologize for the confusion. Got the confirmation form IT team that the NIC id 80-CE-62-3A-2C-1B is valid and form my understanding that you have received it and kindly check and let us know if any issues. Thanks
- Naren
Hi, I'm also having the same issue. Haven't received the license file after multiple requests. NIC: C8-F7-50-67-88-1E. Please help on this.
- kebih
Hello
I have already given up.
I used MAX + for MAX7000S.
I started using an older version of QUARTUSII.
Maybe the function to issue LISENCE is stopped.
I have applied for a license with multiple NICs, but have not received a reply.
I feel that MAX + cannot be used anymore.
- kokum4
Hello
So that's it.
But I use MAX7000, so I can’t use it without MAX + plus II .
Thank you for teaching.
- AR_A_Intel
Hello
Welcome to INTEL forum. I’m escalating this issue to IT team to investigate. A ticket incident has been submitted. We will update accordingly.
- kokum4
Hello
I understand, I will wait.
Thank you.
- AR_A_Intel
Could you provide your NICID for our customer service team verification?
- kokum4
Hello
Currently, I want a license file for NIC = 80-CE-62-3A-2C-1B.
Previously, I had a NIC =74-E5-F9-A1-09-46 file.
Strangely, the product listed in the email I received at that time was "Quartus II Web Edition", but there is no problem because the license file is running on MAX +.
Thank you.
- AR_A_Intel
Could you also advise the following?
Admin Name
Email Address
Company Name
Company Address
- kokum4
OK.
I can write it, but should it be written here?
Or is there some private communication?
- AR_A_Intel
For privacy, you can also reply/attach your file in private message setting.
- AR_A_Intel
Hi Sir
Upon checking with IT team, your NIC = 80-CE-62-3A-2C-1B is not valid and we are unable to generate license under it. Kindly check if the NIC is correct? alternatively you can also provide the Guard Id or other NICID.
- kokum4
Really?
However, I just received an email with the license file (80-CE-62-3A-2C-1B__0-359500883780187.dat).
And the file seems to be working properly.
Tell me, what's wrong with that NIC?
What decided NIC (or hard disk number) that can get a license?
I would like to refer to when the next request.
Thanks for your working.
