Try here ...
ftp://ftp.altera.com/outgoing/release/ - Altera_Forum
That site seems to have 9.0.0 and 9.0.3 but not 9.0.1 where can I get 9.0.1 from? - Altera_Forum
Upgrades to
Upgrades to the 9.0 downloaded from the FTP site are available via the following link. https://www.altera.com/download/sw/dnl-sw-index.jsp. Scroll down to MaxPlus2 in the selection box. For pre-9.1 Maxplus2, you will require an authourisation code as a licence. I would be very interested in hearing about how you acquire one of those. - Altera_Forum
--- Quote Start --- That site seems to have 9.0.0 and 9.0.3 but not 9.0.1 where can I get 9.0.1 from? --- Quote End --- Why do you need that specific version? Which FPGA are you targeting? Cheers, Dave - Altera_Forum
I need 9.0 in particular because we have a safety-critical, certified design dating from 1998 which requires a modification. To change toolset revision (9.0 was used for the original design) will involve a huge amount of work in satisfying the certification authority that the tool change has not introduced the possibility of a systematic error in the rebuild. We've now downloaded 9.0 from the FTP site but have run up against the next hurdle of requiring an authorisation code for the licence.
--- Quote Start --- I need 9.0 in particular because we have a safety-critical, certified design dating from 1998 which requires a modification. To change toolset revision (9.0 was used for the original design) will involve a huge amount of work in satisfying the certification authority that the tool change has not introduced the possibility of a systematic error in the rebuild. --- Quote End --- Sounds reasonable. --- Quote Start --- We've now downloaded 9.0 from the FTP site but have run up against the next hurdle of requiring an authorisation code for the licence. --- Quote End --- File a Service Request with Altera directly and see if they can provide one. Cheers, Dave
