10 years agoMaximum Operating Frequency
Hi everybody, I designed a sample architecture in Quartus 10.1 by using EP4CE22F17C6. I used a bit generator and parallel mux blocks and run all architectures. I connect output of the bit gener...
10 years ago --- Quote Start --- Tricky, thank you for your reply. However, I think that Fmax depends on maximum path delay. In the my design, max. path delay is always fixed. I only change number of parallel mux which consist of same code. --- Quote End --- but thats it - the path is not always fixed. When it does the fit, the logic can get put in different places, so the routing delays can vary from build to build - hence the variability.
