10 years agoMaximum Operating Frequency
Hi everybody, I designed a sample architecture in Quartus 10.1 by using EP4CE22F17C6. I used a bit generator and parallel mux blocks and run all architectures. I connect output of the bit gener...
10 years ago --- Quote Start --- The max frequncy will change depending on the design, routing and random fitter seed. Changing the design will change the routing and hence the Fmax --- Quote End --- Tricky, thank you for your reply. However, I think that Fmax depends on maximum path delay. In the my design, max. path delay is always fixed. I only change number of parallel mux which consist of same code.
