10 years agoMaximum Operating Frequency
Hi everybody, I designed a sample architecture in Quartus 10.1 by using EP4CE22F17C6. I used a bit generator and parallel mux blocks and run all architectures. I connect output of the bit gener...
10 years agoThe max frequncy will change depending on the design, routing and random fitter seed.
Changing the design will change the routing and hence the Fmax
