MAX10 FPGA Pin Assignments for LVDS signals input and outputs
- 7 years ago
Hi Nanjunda,
I tried to replicate scenario & I observed the below results,please try to implement same at your end & if you have any different issue,let me know,
please find the below link & attachments,
https://www.intel.com/content/www/us/en/programmable/documentation/sam1394433606063.html#sam1394435423058
Vikas
Hi Abe,
"Since you've assigned Bank2 as 3.3V LVCMOS and LVDS IO Standard, the IO Buffers in the device for Bank2 are configured as LVDS IO buffers. These can accept single-ended signals as inputs but cannot output single-ended signals."
- Does it mean that I do not have to give a 2.5V supply for the LVDS signals (i.e. to VCCIO).
Am I correct to understand that I can implement any LVDS signals in 3.3V bank but with limitation as no 3.3V single ended output signals are allowed in that bank.
If above statement is right, what would be the common mode voltage of the LVDS signals(from 3.3V bank voltage)?
As per the datasheet, the LVDS signals are defined only with VCCIO=2.5V in the table.
Thanks & Regards,
Nanjunda M
Hi
Does anyone tell me whether my above statement is correct or wrong?
Thanks & Regards,
Nanjunda M
