Gaston
4 years agoMAX10: Dual purpose pins DCLK, nCSO, DATA[0], DATA[1]
Hey everyone
I'm at the very beginning of a project where I want to implement a power converter digital controller on a MAX10 device. I have a little experience, but only with Lattice FPGAs and to...
Gaston
4 years agoThis is what I find in the I/O Assignment Warnings:
This is the list in pin planner:
The assignment editor:
And the top vhdl:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.Counter_pack.all; entity counter is port ( ResetxSBI : in std_logic; ClkxCI : in std_logic; LedxDO : out std_logic_vector(7 downto 0) ); end counter; architecture behavioral of counter is signal CountValuexD : unsigned(COUNTER_WIDTH-1 downto 0); -- count value begin CntStateMachine: process (ClkxCI,ResetxSBI) begin if ResetxSBI = '0' then CountValuexD <= to_unsigned(0,COUNTER_WIDTH); elsif ClkxCI'event and ClkxCI = '1' then -- determine next counter value CountValuexD <= CountValuexD + to_unsigned(1,COUNTER_WIDTH); end if; end process CntStateMachine; -- assign outputs LedxDO <= std_logic_vector(CountValuexD(COUNTER_WIDTH-1 downto COUNTER_WIDTH-8)); end behavioral;
The mesage incomplete set of assignments seems to refer to the only two inputs of the design. The outputs seem to be OK. But I don't understand what's missing.
