8 years agoMAX10 ADC user defined output simulation in Cadence NCSIM
I'm trying to simulate user-defined ADC output using Cadence NCsim. Now, I used defparam to parameterized enable_usr_sim, reference_voltage_sim and simfilename_ch0-16. The ADC model works well w...
8 years ago --- Quote Start --- Did you create the separate text file needed to create user defined output for the simulation? If so, can you post it? --- Quote End --- I basically try the setting in the manual. I used 2.5 as reference voltage.
1 0.2
2 0.5
3 0.8
4 1.1
5 1.4 By the way, I used dual ADC IP core. Thank you for the reply!
