Max V 5M80ZE64C5N examine / Verify Failure still unsolved
Hi TN-Notebooks,
Could you try the following step:
1. Uninstall the current usb blaster driver, then try to update the driver to the higher version, such as usb blaster driver for 17.1 or later version.
2. If it is impossible to update the usb blaster driver ,we recommend you to modify the JTAG circuit on your board, and adjust the pull-up resistor of TCK TMS to modify jtag timing.
Fakhrul
*Please be informed that we will be out of office from 8/April to 12/April due to a public holiday here. Kindly expect some delay in response if you are going to post an update.
- TN-Notebooks2 years ago
Hallo,
i never had or used a version older than 17.1
so fur sure its a usb blaster driver for 17.1 or later version .
Prior last Test i deinstalled ALL Software and installed everything from the latest Quartus lite 23.1
Thomas
- FakhrulA_altera2 years ago
Hi TN-Notebooks,
Upon checking, I found out that the lates supported Quartus software for MAX V is 21.1 both for the standard and lite versions. You may check it here: Intel® Quartus® Software Latest Version for Device Support
Please try with the latest supported Quartus version (21.1) and let me know the outcome.
Fakhrul
