Max V 5M80ZE64C5N examine / Verify Failure still unsolved
Hi TN-Notebooks,
Based on the previous thread you mentioned, I believe you only wanted to examine the board for the cloning purpose, correct?
If you have no issue with examine, may I now the reason you would like to verify it?
Fakhrul
Hallo
"Based on the previous thread you mentioned, I believe you only wanted to examine the board for the cloning purpose, correct?"
--> Yes this is correct
"If you have no issue with examine, may I now the reason you would like to verify it?"
--> This is wrong.
The examined Files are not working - they are empty. Examine is not working.
If i install on a Clone the examined File its not working.
So finally verify confirms correctly that the examine File do not agree with the Source Chip.
Seem that Examine is Faulty by Quartus Software
This Faulty Examine behavior is confirmed with my Boards and a original Development Board.
