12 years ago --- Quote Start --- Created a separate COMPONENT triggered by the 100 MHz clock to create my 12_5MHz clock and instanciated in "Sawtoothx" entity. It seems to work better. I will try an "enable" signal if I see some other issues. --- Quote End --- A component doesn't change anything. At least SAWTOOTH_CLOCK must be registered. (It might be that the combinational expression for SAWTOOTH_CLOCK maps to a single FF output. In this case, it would be glitch-free without being explicitely registered) You have several domain crossing signals with i_clock as launching and SAWTOOTH_CLOCK as latching clock which likely causes timing violations, e.g. current_state. I guess there's no substantial reason for this clock topology. Using SAWTOOTH_CLOCK respectively a new signal that is active for one i_clock cycle as a clock enable is however the straightforward way to get rid of domain crossing problems. Or don't register any internal signals under i_clock control.
