16 years ago
max 300 process
hi
i have a problem with my altera max device.
it does not enter into the process despite the constantly updated clock:
q<=q_temp;
ff: process(clk)
begin
IF (clk'event) AND (clk='1') and (en='1') THEN -- Positive Edge
q_temp <= d;
elsif (en='0') then q_temp<=q_temp;
END IF;
if (reset='1') then
q_temp <='0';
end if;
end process;
thanks
    It seems to me, that you actually meaned to code the below process:
    ff: process(clk)
    IF (reset='1') THEN
      q_temp <='0';
    ELSIF (clk'event) AND (clk='1') THEN -- Positive Edge
      IF en='1'  THEN
        q_temp <= d;
      ELSE
        q_temp<=q_temp;
      END IF;
    END IF;
    end process;
    but the code inside the process isn't executed.
    The device doesn't come in the process.
    i test the code that you have sent me!!! soon
    I assumed, that Quartus would possibly misunderstand the asynchronous (outside clock edge) hold condition
    But I verified, that both variants exactly infer a DFFE primitive in mapped design. So if everything seems wrong, it's most likely a simulation problem. The code behaves as a D-Flip-Flop with clock enable, as it should.
    i have built the project and programmed the device but doesn't work!
    could be a hardware problem on the clock?
    sure that the CPLD covering the process statement?
    I inserted a quartz gclk1 at 8 MHz (pin 43)! without capacitors
    thank's
    --- Quote Start ---
    --- Quote End ---
    Yes, can you verify that the clock is actually present?
    the clock works! I made a program to test it, even if it behaves erratically. Oscillates only if I get close! Where can I find a pattern for the clock?
    I made an asynchronous circuit with a process statement!
    the process is update by a pin connected to an external switch.
    Not work
    ther is another problem.
    does not recognize initial allocations. For example:
    signal a:std_logic:='0';
    however i renew my request:
