MAX 10 ROM/RAM Init failure. Code error on both silicon and simulator. Error (14703): Invalid internal configuration mode for design with memory initialization
Now Flash controller test:
reenable has lost csr interface.
Qsys on reenable report clock and reset error, but they where on place:
double click on both clock and reset remove error.
Data has no address map, double click on data connection restore.
Save (forever twice) generate, then Quartus compile design to end. (not initialized flash.)
reopen qsys, delete Flash IP, select again from IP it is mapped where it was previous, again erase don't work. CSR reappear.
Flash is set as not initialized
Flow Status Successful - Sat May 25 00:11:17 2019
Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Revision Name Top
Top-level Entity Name top
Family MAX 10
Device 10M08SCE144C8G
Timing Models Final
Total logic elements 5,683 / 8,064 ( 70 % )
Total registers 2210
Total pins 95 / 101 ( 94 % )
Total virtual pins 0
Total memory bits 33,476 / 387,072 ( 9 % )
Embedded Multiplier 9-bit elements 0 / 48 ( 0 % )
Total PLLs 1 / 1 ( 100 % )
UFM blocks 1 / 1 ( 100 % )
ADC blocks 0
Reload Qsys, check initialize memory, point to bios for embedded processor, save and generate QSYS.
Quartus compile sa with uninitialized memory.
Browsing .pof and .sof with an HEX viewer no trace of bios is seen on files.
Try with convert programming files...
MAX 10 can be an Heaven to embedded SOC, turn on Hell by software and lack of documentation....
Edit UPDATE:
modified configuration of flash to initialized, added .hex bios files, everything proceeded fine.
Flash content where is stored on .pof? or .sof? I don't see bios ascii messages, nor I see code, just a long FF sequence and some spot of noise, can be cfm
- RRomano0017 years ago
Contributor
About Flash content:
File reside on .pof, is forever scrambled same way, maybe it add some check bit.
Strange scrambling of file was from QSYS, sometimes when forget double save generate code on old design.
If this happen and some IP core got modified, next time on qsys opening ask update Cores.
After that I seen clock was moved from PLL C0 output to main clock.
Correcting this, now flash content on read is stable and close to .hex.
Too many sparse subtle bug affect this tools.
Old bug never addressed still persist on. (Double save)
