RRomano001
Contributor
7 years agoMAX 10 foolished by? WHY???
Simple Edge detector doesn't work, just pipeline of signal doesn't work. monitor of incoming signals, output signals, routed output signals to two pin: On one is stuck at 0, on the other sample S@...
KennyT_altera
7 years agoHi, I had email you another way so that you dont hardwire some VHDL attribute to high for your simulation. As the code itself got some pb where you cant compile it in modelsim.
