RRomano001
Contributor
7 years agoMAX 10 foolished by? WHY???
Simple Edge detector doesn't work, just pipeline of signal doesn't work. monitor of incoming signals, output signals, routed output signals to two pin: On one is stuck at 0, on the other sample S@...
RRomano001
Contributor
7 years agoUpdate:
Entity interface:
-- Interrupt
ETH_IRQREQ : in Std_Logic := '0'; -- Ethernet RX end of UPD packet irq request
ETH_IRQACK : out Std_Logic := '0'; -- Ethernet RX end of UPD packet irq accepted
ETH_Status_Register : in Std_logic_Vector(7 downto 0) := (others => '0'); -- Status of transmitter/receiver
SEQ_IRQREQ : out Std_Logic := '0'; -- Controller irq requestmoved signal out of process to be mere combinatorial....
DMA_ACK <= Local_DMA_ACK;
ETH_SEND <= Local_ETHREG;
SEQ_IRQREQ <= ETH_IRQREQ; -- Controller irq request <-- Ethernet RX end of UPD packet irq request
-- Local_PWR_FLT <= (others => '0');
-- Local_MODECFG <= (others => '0');
-- RD/WR Status flags
SEQ_Debug(3 downto 0) <= Local_StatePrb; -- state counter
SEQ_Debug(4) <= Local_DMA_ACK;
-- SEQ_Debug(5) <= Local_DMA_IsRDing;
SEQ_Debug(6) <= SPI_WR_READY;
SEQ_Debug(7) <= SPI_RD_READY;
SEQ_Debug(5) <= ETH_IRQREQ;
-- SEQ_Debug(6) <= '0';
-- SEQ_Debug(7) <= '0';
-- Entity - Signal connection End ----------------------------------------
--------------------------------------------------------------------------Signals:
ETHIRQ on this module from debug signal. (Element 5 of vector)
ETH_IRQ on external generating module
SEQ_Irqreq outside this module.
Freezed project files to document this again fool issue.
LA pin is low, uController sample High, seems SEQ_IRQREQ disappeared from design and default signal take on place.
Edit:
Top module:
Entity:
-- --- STM IO ---------------------------------
TXDE1_ST : inout Std_Logic := 'Z'; -- Released to controller
RX1_ST : inout Std_Logic := 'Z'; -- Released to controller
TX1_ST : inout Std_Logic := 'Z'; -- Released to controller
TXDE2_ST : inout Std_Logic := 'Z'; -- Active serial to Perihery
RX2_ST : inout Std_Logic := 'Z'; -- Active serial to Perihery
TX2_ST : inout Std_Logic := 'Z'; -- Active serial to Perihery
JTAGEN : out Std_Logic; -- User free I/O
-- signals:
signal Local_irq_req : std_Logic := '0'; -- IRQ Requestconnection:
Local_irq_req, is mapped to external module SEQ_IRQREQ interface.
TX1_ST <= Local_irq_req;
JTAGEN <= Local_irq_req; --Local_SPI_Debug_Port(20); --SPI_MOSI1; -- LA 3 Local_Debug_PortW(3)
