8 years agoMATLAB to VHDL conversion
Hello everyone, I have a (VHDL) code for calculating a (Transfer function) that I generated from (MATLAB). I have the program attached below. When I run the program it gives the following message...
8 years agoReal type is not suitable for synthesis. You should look into using the floating point IP cores.
