Maths Error
- 6 years ago
Why not do a fully synchronous design with all the registers clocked on posedge clk ?
Create an enable signal for the data processing block and include all the logic inside that block within it:
always @ (posedge clk) begin
if (enable_enc) begin
... do stuff ...
end
end
... do stuff ...
end
end
Two questions.
Why would that work when my solution does not?
What is best practice for implementing enable_enc?
- ak6dn6 years ago
Using a single synchronous clock with optional register enable(s) is simpler for Quartus to meet timing than deriving a bunch of signals that will be used as clocks. FPGAs only have a limited number of low skew, high drive clock layout resources.
As to implementing the enable signal, that is just some simple logic driving a register to create a one clock width pulse at the posedge clk when you want the logic to trigger. No special techniques needed.
